Does anyone put Z-Max in their IS-F? I put it in my IS300 and IS350 but I'm thinking it was for my own benifit...not the cars. Just curious...getting my first oil change today. This is my first V8 so I'm wondering if that tiny bottle of engine additive can really make a diff.
As Bulls said....NO there is not a single reason to add that to your IS-F. I know that Mr. Shelby promotes it, but that doesn't mean you should add it.
IMHO, the only additive worth using is Chevron Techron. And it's often on sale or two-for-one at various auto parts stores. Use every 2,000 or 3,000 miles with a full tank of gas and refill 20 miles after the Estimated Range display reaches 0. You get an additional benefit if used with Chevron gas.
All the other additives actually do harm. For example, ones that claim to penetrate the cylinder walls must be useless and can change the chemical properties of the metal; you want lubricants on the surface. Duh!
Also, use the TRD synthetic oil filter at the next oil change; much better than the Lexus filter and available at any Toyota dealer off the shelf or special order. You should be able to get 20% off the price just by asking. The part number is: PTR43-00081
If fuel economy is your concern, the two effective things you can do is: (1) moderate use of your right foot, and (2) check and adjust tire pressures (I use 39psi).
Related Threads
Lexus ISF / IS-F / LFA / LF-A Forum
36.7K posts
16.1K members
Since 2007
A forum community dedicated to Lexus LF series owners and enthusiasts. Come join the discussion about performance, modifications, classifieds, troubleshooting, maintenance, and more!
