Yes, I want to know the same.Hey does anyone have these on their ISF? Just wondering if you will need to change camber because of the lowering difference??
You're correct, there is only one style of Tein spring available right now, the H.Techs. The Tein coils are the comfort sports and are available with the EDFC capabilities. I would do an online search of authorized Tein dealers or talk to some sponsors on here or CL to see if they're running any specials or have a lower price for you.Are there only one type of Tein spring style that you all are using? I looked at their website and they only have one type of spring set for the F (other than coilovers), I believe it was called the HighTech... listed at $345, what did people pay with install?
You're exactly correct, due to the fact the drop is around an inch, there really isn't a negative camber. If there is, it's extremely minimal. I can try to find my alignment sheets from when I first put them on if you'd likeHow bad is the neg camber after the install? I would think an inch wouldn't move it to bad. As Scions have OEM TRD replacement springs that bring it down 1.25 and zero need to change camber.
