Rear spoilers are one of the most popular auto accessories available on the aftermarket. From mild to wild, a rear spoiler can change the entire look of any vehicle. If you want the spoiler, which after mounting has a factory installed look, then the factory style spoiler is exactly what you need. We have 2 exclusive options from T5i and Remin, which you might find interesting.
T5i® - Factory Style Flush Mount Rear Spoiler will perfectly complement your car's fine lines, and its distinctive shape will set your car apart from lesser models. It delivers a sporty image that is easy to be recognized. Made from ABS plastic, installs easily with 3M™ tape and screws, backed by a 3-year warranty.
Remin® - Custom Style Rear Spoiler enhance vehicle's exterior as well as improve its maneuverability. It helps to give your car the same look as the high-performance models. It improves aerodynamics, has factory style, made from automotive-grade ABS plastic and installs easily with screws and gaskets.
Both spoilers are available in Unpainted and Painted versions (you can check the paint code by VIN# or with paint code labels, located at the driver side door jamb).
You can learn more about those brands with the following links:
T5i http://www.carid.com/t5i/
Remin http://www.carid.com/remin-dash-kits/
Check prices for your model and see other details here: http://www.carid.com/2014-lexus-is-spoiler/
Which one you think would be the best for your vehicle?
