1 - 2 of 2 Posts
Registered
Many of us are torn by the dilemma of buying the first car or leasing it. If you are just starting your career (even if you are in the middle) and if you have a huge appetite for cars and change, and if you are one of those who are torn between the options mentioned above, this article is for you. . This article explains why leasing is the right option for you. This article details all the things you may or may not know, but dare not confront. The following is a list of the advantages of leasing a car over buying a car. For Essex car rentals and Oxfordshire car rentals, consider PJ Car Leasing.
When you rent, avoid tying up your money
2302
A car is a great investment. If the truth is that it is a type of investment with a high depreciation value (in percentage), this is because it requires maintenance, which is absolutely important. Sometimes it can even become a larger liability if the ratio of profit or loss is less or zero or a violation. Also, would you like an investment that sits outside your home only to depreciate over time? Certainly not. This is something that the younger generation understands. And for them, leasing is a very viable option.
You can control your monthly expenses on your car: -
This is a great advantage of renting a car. When you rent a car, the monthly expense on the car is known or clear. For example, you know there will be some expenses for fuel (which you can easily estimate, based on your average monthly car use) and insurance. Apart from these two, variable expenses such as highway fund license, breakdown coverage, maintenance cost, etc., will be included in one group. This is very useful as you can easily keep track of expenses and you can control it since you know where and how much you are spending each month. See more W88
The MoT nuisance can be easily avoided: -
You should know that for cars there is no annual MoT fitness check for the first three years. Only after the third year is Mot required. But when you rent a car, you won't have that car for that long, which means that the car is no longer your responsibility and therefore not an MDT. So this becomes an advantage.
End the monopoly of distributors: -
As we mentioned earlier, these renters are basically auto brokers who give you the most optimal rates by studying the ebb and flow of the market. Basically they keep checking the market and this is a very good advantage as it destabilizes the monopoly of the distributors in the market.
1 - 2 of 2 Posts
