Sirius Radio MOD
2134 Views 2 Replies 3 Participants Last post by  rutiger
Hello, this is my first post, bear with me if it is a little off the normal format. Here is my question, I am looking at putting in the Directed Electronics mod kit for Sirius radio. Has anyone had this plug-n-play mod put in their "F"? Where you able to use the "shark-fin"? I was at Car-Toys today and they said I would not be able to use it. I found this hard to believe. Please respond. Thank You. POODLES
1 - 3 of 3 Posts
I have sirius installed by the dealership, and there is a separate antenna...they do not use the fin either, so it probaly is true what you have been told.
As far as the mod kit, no answers for you. sorry
they mounted my antenna on the white bubbly part of the winshield, first to the right of the rearview...then the left after i complained about the signal. for some reason it the left side does not give me any trouble.
car toys is wrong. you can use the sharkfin as long as you get the adapter cable. some places use some stick on antenna on the windshield. looks like crap.
i did the install myself, but for some it may be more work than you want to do. only tough part was removing the center console (the center air vents suck!).
here's what you need:
- sharkfin adapter (http://www.tss-radio.com/lexus-and-shark-fin-antenna-adapter-p-5646.html)
- interface unit and sirius module (http://www.tss-radio.com/lexus-sirius-interface-package-p-4046.html)
you can probably find this stuff for less elsewhere, but those are the parts i ordered. been using it since last year and it works great. i have the interface and radio modules under the passenger seat. ran the cables for the radio and antenna under the plastic trim and carpet. it took me a few hours to install it myself.
the sharkfin adapter connects in the trunk. you need to pull back the carpet on the right side of the trunk and you will find an open connector there to plug into. it's pretty obvious as it's the only thing you can connect to in that area.
1 - 3 of 3 Posts
