Question for ISFLY168
2353 Views 3 Replies 3 Participants Last post by  kcb77
Was able to put my HID Bulbs in with no problems. I wanted to ask you if there is anything I should be concerned with when i install the HID Fog light kit (xentech)?
Also, Im looking to replace the parking light bulbs that is next to the DRL. When I had the engine bay covers off I wasnt sure how to get to it. Is there a cover I have to pull off? Maybe you can help me out...
1 - 4 of 4 Posts
just take off the two or three front clips on each fender liner and you will be able to reach your hands in for the foglights, it took me 10 mins a side the most. for the little 168 bulb on top of the drl, you have to take off the cover for the high beam and its basically right there. Im actually gonna change my high beam bulbs to led this weekend, I'll post picts after Im done.
Let me know how you make out.... I think I do remember seeing some black covers on the back side... Do they twist off? Are there bolts? Im going to attempt my HID foglight kit on saturday... Hopefully all goes smooth... I have 168 led bulbs just need to put them in... I'll see if i can figure it out.... I would like to see pics of your DRL conversoin...
Thanks
Thanks
I just changed out my High beams 9005. I had a little issue with accessing the driving side compartment because of the wiring harness and windshield wiper fluid tube. The passenger side was no problem because the stock air filter has been removed.
I was able to remove the black covers by unscrewing the top screw just enough to slide the metal rod out from under the screw head. There will be two places on the black cover that the metal rod will rest in to hold the black covers. Remove the metal from these two areas. There will be two or three tabs on the opposite side the metal rod that hold the black cover in. So pull towards the engine on the metal rod side to assure you do not break off the tabs.
After that it is the normal twist the bulb to remove it from the housing. Good luck. Sorry I did not take pics, hard to do when its only me.
Bryan
1 - 4 of 4 Posts
