I got some ceramic pads for $127 and installed them yesterday. Here is a picture showing the notch everyone is talking about.
Actually I paid $127 for the fronts and yup it includes both wheels.Excuse my ignorance, but you guys are saying like $275 for the fronts, are we talking about both wheels, or per side?
Can you tell us where we can buy some too at that price, PLEASEI got some ceramic pads for $127 and installed them yesterday. Here is a picture showing the notch everyone is talking about.
Look at the third post on the first page. They have the ceramic pads for that price.Can you tell us where we can buy some too at that price, PLEASE
Yes the third on the first says 220, not 127.Look at the third post on the first page. They have the ceramic pads for that price.
I sent you a PM last night with the contact info. And yes $127 is the right price for these pads. This price includes the shipping too.Yes the third on the first says 220, not 127.
I already got a set from priceshopper, will have them on next week.
How are you liking the pads? My only gripe with them so far is high speed slow downs. They appear to heat up quickly and give the car a weird braking noise. Other than that they are quiet, very low dusting and comfortable to use.Yes the third on the first says 220, not 127.
I finally got up the nerve to replace the front brake pads myself. Local Lexus dealer had quoted me in the upper $900s! So I ordered some Ferodos from raceshopper.com (see first page of this thread) for $223 I think it was. They got here pretty quickly and I was able to have a go at it this afternoon.Hey all, nice spam on here... I fitted the pads Sunday. Great news, its easier than a pad slap on low end cars. Low end brake systems, (read) most require removal of caliper to fit pads. ISF just slip out of top after pin removal. Its actually less labor. The whole job took an hour in the garage. Of course I did clean & lube all pins & movin hardware. The pistons 6 per caliper I was able to push back with my fingers evenly till they bottom in the bore. The calipers are embossed brembo in very small LOGO on the top of the caliper. The finish is first rate. Moving along, the ferodos work nicely, after bed in intial bite is similar to stock but as I increase pressure the bite seems a bit more aggresive which I like. As for track time with these I will see in spring. The price was right & the job is easy if you know cars & brakes. Its nice to see that any work can be done at a home shop. especially if the dealer quote is 700$ Cheers & Happy New Year to all. Hope to see some of us at the track in 09
Despite pads used, is it necessary to replace the rotors? I was told by dealer that they could NOT be cut/resurfaced?
My dealer in Orlando told me to my face the rotors CAN be turned (cut/resurfaced).What is the truth!! Anyone know?
You can cut/resurface cross drilled rotors. However, it is not recommend. Many modern cars now have the rotors and pads matched to wear out at the same rate so you replace both at the sametime. (This however does not seem true for the F since the front pads seem to go pretty quick). The reason many will say that cross drilled rotors cannot be cut/turned/resurfaced is that it is not uncommon for the holes to catch and break the cutting tool they use to resurface. This is a pain and expensive for the person doing the work since they have to then replace the cutting tool(bit). In many cases unless you have severe pad compound build up on the rotor, there is no need to replace the rotor until you hit the minimum tolerance for thickness. Also remember (as mentioned before) removing material removes mass for absorbing heat. Essentially that is what a brake does, turns rotational energy into heat.
Bedding your new pads will be very important, follow the directions that come with the pad. Some call for slow easy bedding, some call for a succession of 80mph-20mph fast stops (usually 3x). Make sure you do the right one.
So because of the issues and difficulties that can result from turning a rotor that has been cross drilled many will simply say it cannot be done and rotors should just be replaced.
A few other comments as I weigh in here. The Brembo calipers are probably one of the easiest systems to change pads on that there is. It is not a hard job to too for any garage mechanic, even if you don't have much experience.
One more thing. The discussions here about brakes are almost verbatim to those that go on in the Porsche community since they use essentially the same braking system on the 911. (accept for pad availability because there a million pads for the Porsche.)
Has anyone checked out Pagid? They make a great pad.
Which ones did you go with? The Carbotech Bobcat 1521's?I went with Carbotech . F&R were under $350 delivered. They work great after bedding in .Probably a 90% reduction in dust. By the way my installer DID turn front rotors and told me you need to be very careful , but it can be done. So far so good ,they don't have the initial bite of stock pad but otherwise they work great!
