FALKEN AZENIS RT-615K
UTQG: 200A,A (All Sizes)
Click here for: Sizes, Specs, and Pricing on the Azenis RT-615K
Additional specs can be found HERE
PRESS RELEASE 11/6/09
Falken Tire is proud to announce the launch of the new Azenis RT615-K. While the original RT615 proved to be a dominant force in the DOT approved and truly street functional competition tire category, we’ve decided to make it even better. The K in the new RT615-K can have many meanings but none describe the second generation 615 better than KAIZEN. By definition, this Japanese word means "continuous improvement" which precisely describes the newest edition to the Azenis lineup. Visually, nearly identical to its predecessor, the subtle K on the sidewall is the only tell tale sign of what lies within its completely revised tread compound.
TECHNOLOGY
- NEW & IMPROVED TREAD COMPOUND that effectively maintains grip as tire tempuratures increase
- MASSIVE SPORT SIDE SHOULDER BLOCKS deliver motorsports level grip and unsurpassed durability
- THREE HIGH VOID/LOW TURBULENCE GROOVES increase maximum wet weather speeds and by reducing hydroplaning tendencies
- SOLID CENTER RIB significantly reduces wheel spin by reducing contact patch void ratio under heavy acceleration
- OPTIMIZED AQUA TUSK POSITIONING reduces tread squirm while delivering flagship wet grip
With an advanced motorsports-grade compound, grip remains strong as tire temps rise. This allows for increased entry and exit speeds on the track, resulting in improved lap times, as well as better handling and control on city streets and freeways.
In addition, the special 8/32nd molded tread design reduces the new tire’s tread squirm while providing efficient mileage for street use, and a solid center rib significantly reduces wheel spin by trimming the contact patch void ratio under heavy acceleration.
Even with an 8% reduction in unsprung tire weight, the Azenis RT-615K performs well in the wet, with optimized aqua tusk positioning that allows better tread adhesion as it delivers ample wet grip performance. Accordingly, wet weather speeds can be achieved and maintained as potential hydroplaning tendencies are reduced.
Falken’s engineers recognized the tremendous demands placed on the Azenis RT-615K, so the focus continues on strengthening its versatility and multiple capabilities to deliver the strongest performance tire for street and track conditions.
REVIEWS
Customer Reviews
Tyler McQuarrie Tire Test: Falken Azenis RT615 VS. “NEW” RT 615K
Video Comparison: RT615 VS. RT615K
MEDIA
If you are running the Falken Azenis RT615-K, post your review here along with a picture or two. We, as well as Falken, would love to read them.
