There are numerous front license plate bracket types on the modern aftermarket. The most secure bracket requires some drilling, so you will have two holes and respectively two bolts on your license plate. If you do not want to drill anything, you may go with the brackets, which have got clamps in. Regardless of the option you choose, if you order one from CARiD, we will make sure you get the license plate bracket that will last. The majority of brackets by Replace, Westin and URO parts are backed up with 2+ years of warranty, and are a fair alternative to the costly OE replacements.
