The 2008 Lexus IS F is exclusively powered by a performance-tuned 5.0-liter V8 engine producing 416 horsepower at 6,600 rpm and 371 lb.-ft. of peak torque at 5,200 rpm. With the implementation of a dual air intake system, high-flow cylinder heads with titanium intake valves designed by Yamaha, Variable Valve Timing with intelligence and Electrically controlled intake cam (VVT-iE) and other technological advancements, the engine outputs 83.2 hp per liter allowing the IS F to accelerate from 0 to 60 in a blistering 4.6 seconds and achieve a maximum track speed of 170 mph.
The IS F 5.0-liter engine is mated to the world's first eight-speed Sport Direct-Shift automatic transmission with a quick and direct special lock up clutch and a control system that enables ultra-quick manual upshifts (0.1 seconds) and blips the throttle for precision downshifts. The driver can shift manually using either the console shifter or steering-wheel-mounted paddle shifters when driving in either Drive mode (D) or Manual mode (M). The new transmission blends the performance characteristics of an automated manual-type transmission with the smoothness and refinement of a planetary-type automatic transmission, allowing the driver to choose between ultra-quick manual shifts for spirited performance driving and smooth automatic shifts when convenience and comfort are the top priorities.
Tested and tuned on some of the world's most challenging racetracks including Nurburgring Nordschleife and Fuji Speedway, the IS F has been designed for ultimate performance. Although using the basic double-wishbone front suspension and multi-link rear suspension configurations of the standard IS platform, the IS F benefits from a multitude of track-proven modifications that include increased spring and damper rates as well as larger-diameter stabilizer bars. The IS F also sits an inch lower and features suspension bushings and a calibrated Electric Power Steering (EPS) system tuned for a more direct feel.
In addition to the finely tuned suspension, a specially calibrated version of the advanced Vehicle Dynamics Integrated Management (VDIM) system is equipped to provide superior handling dynamics and traction control. The IS F is also outfitted with a heavy-duty Brembo® brake system designed to the specifications of the Lexus engineering team. The 14.2-inch ventilated, drilled front rotors are gripped by rigid, powerful six-piston aluminum calipers, while the 13.6-inch ventilated, drilled rear rotors use two-piston calipers.
With new and distinctive high-performance design features, the IS F is set apart from standard Lexus models. The IS F exterior styling has a muscular stance with front fascia, hood, fenders, underbody and rear spoiler all shaped to optimize airflow management and give the IS F a signature look. Unique “F” badges composed of silver, blue and black are located on both front fenders followed by a third badge on the trunk lid. Four exhaust diffusers, stacked two per side in a vertical arrangement, are integrated into the rear bumper and leave a lasting sporty impression. The IS F continues to differentiate itself from its siblings with its 19-inch forged-alloy wheels produced by BBS® that feature a distinct dark-gray finish.
Standard amenities include heated, leather-trimmed 10-way power front sport seats, dual-zone automatic climate control, a pollen filter and smog detector; power moonroof with one-touch open/close and seven open-position settings; power tilt-and-telescoping steering wheel; three-position memory function for front seats, steering wheel and mirrors; all power windows with automatic up/down operation with jam protection; an auto-dimming rear-view mirror with HomeLink® programmable garage door opener, SmartAccess keyless entry and push-button start, Lexus Premium Audio System with six-disc in-dash CD changer, automated rain-sensing wipers and heated auto-dimming outside mirrors with integrated puddle lamps. Options include a DVD Navigational System with backup camera, 14-speaker Mark Levinson® Surround Sound Audio System, Intuitive Park Assist, Pre-Collision System, and headlamp washers.
MSRP does not include a delivery, processing and handling fee of $765.
http://pressroom.toyota.com/Releases/View?id=TYT2008011143506
