I would wait until this morning to see what happens when you try to start it. Did you have trouble starting it when you picked it back up from the valet?
When you tried to restart it three times, did the ignition fire and it not catch or did the engine not even try to start? Was the little light on the push start red or green?
If it starts up fine in the morning then I would guess it is all good and it could have just been the placement of the key, if not, try using your other key fob, they gave you two correct? If it works better with the second one then you have a problem (dead battery, etc.) with the first.
Let us know what happens and how it goes
