Sometimes thats too small, depending on the wheels specs and clearance.min of 18" on the F
Yeah, the 18" MSW wheels I have for my snow tires just barely clear the front calipers. Thankfully the Tire Rack could recommend wheels that fit.Sometimes thats too small, depending on the wheels specs and clearance.
Give us more of what your looking for chinkzzzDo you know what size you want to go with? Lightweight, forged, 1 piece, 3 piece, etc? Do you have any in mind? Pics?
thanks bigmike, I'm thinking running on 20" 1 piece forged. gtr-face. have no idea in mind what rims should go with, just had a thought of volk progressive te. and good suggestions? thanks again...Sometimes thats too small, depending on the wheels specs and clearance.
Our system says the factory specs are as follows:Does anybody know what the stock offsets are on the F? This seems to be pretty difficult information to get. I don't know whyI can't find it anywhere in Lexus's specs.
do you know whats the best fittment for aftermarket rims? I'm wishing to go with 20" but it wouldnt hurt to know whats 19"and 20" both.Our system says the factory specs are as follows:
Front-19x8 et 45
Rear -19x9 et 55
Our fitment guide is a little more conservative. We suggest the following:do you know whats the best fittment for aftermarket rims? I'm wishing to go with 20" but it wouldnt hurt to know whats 19"and 20" both.
front 19x9 et?
rear 19x10 et?
front 20x9 et?
rear 20x10 et?
or is there any other better suggestions? please let me know. thanks!!!
The sizes you list are certainly the closest to OE rolling diameter. I can tell you that a 19x9 with a 45mm offset will not rub on the front running a 255/35-19. On the rear, 19x10.5 with a 60mm offset will not rub with 295/30-19. Some people prefer a tire with a little more meat on the sidewall. Anything below 3% is acceptable on the IS-F.I disagree with you both on the tire sizes. Using those sizes will increase the OD by an inch and throw off the speedometer. To maintain the stock height, go with 245/35/19 and 275/30/19. When my OEMs go, I'm thinking about going with 235/40/19 and 265/35/19 on the stock wheels. A little bigger in diameter, but not enough to really matter, IMO. However, there seems to little room in front, and I'm reluctant to going any wider than 235 in cross section. Also, at this point in time, there doesn't seem to be a good solution (read selection) as far as tire brands and models for the two sizes I have in mind.
