Composite lumber flooring is a wood-based panel substrate for the new floor. The past 20 years, with the rapid development of decorative material industry, composite lumber flooring surface decoration materials has become one of the main products. The product with its elegant appearance, rich color, abrasion resistance, scratch, without polishing, waxing and painting always clean as new features favored by consumers. Then laid composite flooring, how to maintain it in the daily life?
1. After completion of the laying of the floor immediately, to keep the indoor air circulation.
2. Overweight items should be stable resting place, furniture and heavy objects are not hard-line sliding boxes to avoid scratching the surface wear layer.
3. Do not scratch with a sharp object, designated floor surface.
4. Do not use water soaked the floor, if unexpected, should be dry with a dry mop the floor.
5. Keep the floor dry and clean, if any dirt floor surface, generally is not dripping tide mop dry.
6. To prevent cooking baked floor was deformed.
7. Should be placed in front of a rub pads, reducing wear and tear on the sand floor.
8. Clear the spots and stains using special cleaning agents floor. Unavailable damage property clean items, such as metal tools, nylon friction pad stains and bleaching powder.
