technically speaking...... you should already be in the optimum gear for the corner before turning in. so all your shifting should be over with. trail braking a little bit at the start of the corner would help reduce the initial understeer on turn-in, but brakes should not be applied in a corner. also, accelerate through the corner by gradually increasing pressure on the gas pedal until the limit is reached. at that point, upshift as needed.
