It's under the plastic piece on the passenger's right side at the back of the trunk. You'll need to take up the trunk plate over the spare to lift the piece on the right. Changing just the speaker is not going to help. That's why I went with a separate sub and mono amp. Search over on CL - lotsa info there.Good luck with that speaker. I wonder if just changing the speaker would increase the bass level? Does anyone know where the stock amp is at and can it be easily changed out for something with a little more umph? I don't really need more, just would like more at times, but don't want to lose any space.
Thanks, When I get some time I will look over at CL. I just like it here, but I do miss a lot of information over there.It's under the plastic piece on the passenger's right side at the back of the trunk. You'll need to take up the trunk plate over the spare to lift the piece on the right. Changing just the speaker is not going to help. That's why I went with a separate sub and mono amp. Search over on CL - lotsa info there.
Yeah, we're friendlier here!Thanks, When I get some time I will look over at CL. I just like it here, but I do miss a lot of information over there.
