Eta?
27360 Views 164 Replies 29 Participants Last post by  doublexl
i dont know if im as curious as others, but to put it bluntly.... where the [email protected]#$ are my headers?
the "they should be ready in 3 weeks" was up almost 3 weeks ago. i'd like to get them on my car before it [email protected]#$ing snows this year.
SIKKY!?
61 - 80 of 165 Posts
Are you going to dyno it too?
you best be kidding or i'll come down there and show you what aBOOT can do. :p
hahahahaha
Does this require the engine to be taken out?
No you just drop it a bit.
Looking forward to independant dynos and pics?
received my headers today. happy they are here....... not exactly satisfied with the quality tho..... jig marks everywhere, holes in welds, single welds on flanges, connections are not machined flat, no new gaskets for the block and some pretty un-circular openings for the exhaust to enter into.
we'll just say i will be mending a few of these items pre-install.
call me anal, but i'm german, precision and quality is in my blood.....
but as long as they perform right?
i saw the same flaw friend
the quality is so so ...:confused:
the biggest flaw is the 4 hole where the headers connnect to the engine ...
is not match at all almost octogonal not round
add this to the bitch list. both flanges that bolt up on the engine side are bowed in the middle. the right side is minor but the left side is very noticeable.
everybody check your headers. also, new gaskets are $72.75 each if you want to go that route. canadian price.
Nice quality! You guys will crap when our productions come out! Stainless and tightly welded!
I have non of those issues with the elite prototype headers. glad i made my choice ;)
here is what i spent 3 hours on this evening. half of one flange almost done, still gotta touch it up. the left side is my work, the right side is untouched except for a pass with a grinder.
there is some undercut that is too deep around the weld to file out, and the one scar is from whatever grinding went on at sikky, also too deep to file out. the bulk of material removed with an air grinder, followed by a lot of elbow grease on a hand file, followed by a die grinder to port the opening, and a finishing wheel to make it all smooth. still need to go over them a couple times, but u get the picture from how they came, to how i am improving them.
Keep us posted. Issues like this still keep me weary about getting the headers.
You guys with quality issues should have contacted sikky and returned them to be fixed. I'm sure he would take care of things. I don't know what changed from the prototypes but the headers I have fit perfectly.
i bet the ones i have would have fit too, after all what are gaskets for.
they were just not to my liking.
Doublexl, those raised areas are there for a reason. You should not have removed them. They are supposed to be there to ensure a perfect seal with the stock gasket. This raised weld creates a pinch point around the cylinder and eliminates the chances of flange warping causing a leak problem. This is not an issue of quality at all. This is outside the port and has no effect on power or function (clearly based on our results) other than to ensure a good seal. There is no need to supply new gaskets for the head because the OEM are metal and re usable almost indefinitely.
Our power gains and testing speaks for itself, there is no issue of quality just your opinion.
You should have contacted us directly if you had an issue. We stand behind our stuff 100% and if for any reason you were not happy before install we would have gladly taken them back. Now it is obviously too late for that since you have modified them.
mating surfaces should be flat. now that i have one finished i can comment on the poor weld quality. no back welding and a ton of undercutting on what is supposed to be a flat surface for a good sealed connection. also there should be a clean connection between tube and flange. i did the best i could short of re-welding the insides then grinding them smooth.
which would you rather install. this
or this
i know which one has a lower risk of pinching a gasket due to uneven surface....
here is before
here is after
and like i said, the undercutting and tool marks from previous are too deep to "safely" remove... i already have 8 hours into this one side. and they are definitely straighter and more even then before i took my hands to them.
Maybe you should of left the product alone. My fittment is perfect. The numbers are good 40+rwhp (I made closer to 50) no CEL, and no other problems. I just don't hope you cause yourself any other problems down the line. If you had an issue you should of contacted Sikky like cayman said. They would have worked with you they are a good group of guys.
Hello Doublexl -
Dude, I'm afraid you're wrong on this.
Grinding off those cups simply isn't something you should try to do by hand and by eyeballing it. Thousandths of an inch make a difference... In addition, the amount of surface area that now must have a complete seal is significantly increased. With heating and cooling cycles, I think you'll have an issue with seals as a result...
Those cups provide a way to leverage the flange such that the seal is at each port...not along the entire length of the assembly.
At any rate - good luck with the project. Mine will be installed on Monday as received from the manufacturer!
Regards,
Mike
if the raised welds were perfectly round and to the exact size of the gasket, i could consider taking your word for it. but the fact of the matter is that in some places on the flanges, the welds are 1/4" wide, and in a lot of places, they are 1/8" wide and some places even less than that. so the gaskets would have to basically be perfectly placed around the header to get a good but still uneven seal.
by making a flat and level surface, it ensures a more uniform seal on the gasket around the exhaust port. therefore more evenly distributing the exhaust gas pressure on the entire ring. furthermore, by smoothing out the hard edges of the weld going into the tubes, allows for better airflow. if i owned a flowbench, i would test it out, but rounded edges are better then sharp edges any day.
i know for a fact that the flanges of the joe z exhaust on my car are perfectly flat, and have the same type of gasket you provide for connection to the exhaust system.... which are full flanged sized gaskets, meant to seal the entire surface area not a tiny 1/8" wide rim around the inside.
back to the header, since there will be no metal to metal contact, due to the thickness of a gasket being in between. my flat and even surface would seal with the exact same force as your raised welds, given that the gasket itself looks to be around 1/4 - 3/8" wide around the exhaust ports. again, with the varying width of the raised welds, some parts would utilize 1/8" width of the gasket and even less in some places, that is a pinched gasket.
and as for my "eyeballing" of straightness. before and after comparisons, as well as numerous checks during the hand filing, using multiple straight edges and a machined flat piece of metal on a table saw would confirm that the header now is closer to flat then it was with the raised welds. also, the files themselves are perfectly flat, or else what use would they be. i have 8 hours into working on this one side, as little metal as possible was taken off. each port is perfectly flat around the diameter of its opening.
now i'm done ranting, im not going to argue anymore, because i know that i just made a good product, better, and probably more reliable.
just for fun, use the internet, and search for header flanges, 99% of them have flat faces, with no raised points for "sealing" the gasket. case closed.
i'd rather do it myself cuz i know it will get done to my satisfaction and in a more timely manner most likely considering shipping and whatnot. also the fact that its been more then 2 months since i ordered. also, i dont really know if you can talk about the fitments unless you personally handled the headers and installed them yourself......am i right?
