My money says that JET PERFORMANCE won't be able to tune the ISF ecu adequately, IF at all.
I like your set-up. Where did you get it ported? For your lights, where did you find the parts?My money says that JET PERFORMANCE won't be able to tune the ISF ecu adequately, IF at all.
Not sure what you are trying to say here. This is their standard PR stuff and does not mean it works with any specific vehicle.JET PERFORMANCE STAGE 2 POWER CONTROL MODULE -- Adds up to 25 h.p.; Improves throttle response, acceleration and low end torque; Allows you to gain maximum performance from point by point air/fuel ratio, ignition advance and various other tuning points; Features dynamic spectrum tuning that provides power gains across the entire power band not just at full throttle; Designed for performance enthusiast; Offers more aggressive programming to make the most horsepower and torque available; Its fuel and timing curves are extensively modified for peak performance and drivability; Requires use of 91 octane fuel, 180 degree thermostat and free flow exhaust; Works well with aftermarket intake systems, mass air sensors and TBI spacers; Easy plug-in installation; With Jet Performance limited warranty.
No offense taken.^^I am trying to say this as respectfully as possible but you have little knowledge of tuning and have no idea what you're talking about. Please read about overcam engines with variable cam tuning. You are shutting down any attempts at a tuning solution.
