Take a look at one of Hankooks newest tires. The Ventus EVO 12. This tire was release not too long ago and its quickly gaining in popularity. I have been more and more impressed with the product I have see Hankook deliver and this one is no exception.
Here's what Hankook says:
Hankook Ventus tires are designed to deliver the ultimate in handling by offering exceptional control and superb braking. Hankook is able to achieve this level of performance by using innovative Multiple Tread Radius design and advanced compound technology. The Hankook Ventus V12 Evo K110 tires provide the precise control and superior responsiveness that are required for performance under extreme driving conditions.
Click here for: Price & Availability
TECHNOLOGY
-Solid center rib block
The solid rib block in the center enhances braking performance. It also ensures optimal ground contact pressure and control response at high speeds for excellent handling.
-Efficient water drainage
Wide linear grooves and aggressive Y-shape pattern design effectively channels water away from the tire.
1) Jointless Bead Wire & High Hardness Bead Filler:
Improves high speed stability while maximizing steering response and durability without sacrificing ride comfort.
2) Wide, High-Tensile Steel Belts & Jointless Two-Cap Ply:
Enhances tread strength for added steering response and wear resistance. This also improves uniformity for a smooth ride and durability.
3) Rim Protector
Provides better protection against outer shock or rim scratches.
-High density nylon reinforcement belt:
Optimized for even distribution of ground contact pressure during cornering.
REVIEWS
RECENT TEST RESULTS
If you are running the Ventus V12 Evo post your review here along with a picture or two - we would love to read them
TECHNOLOGY
3) Rim Protector
REVIEWS
RECENT TEST RESULTS
