i know there is a guide to detailing thread but i have this one in several other sites and i'ts came in handy for alot of peeps, let me know if this is a ok thread to start....
Detailing tip of the week: when fully detailing the exterior of your car (wash,clay,seal,glaze,wax) you should be using 6-12 towels min. preferable double sided microfiber towels with silk trimming
Detailing tip of the week " when applying dressing to your interior vinyl apply gently as if you did with wax in a circular motion but to reduce it from attracting dust after applying the dressing, simply wipe down with a microfiber towel to give it a fresh look" http://www.smartwax-usa.com/ProductDetails...Code=SM_INC_102
detailing tip of the week
"applying carpet cleaner to your carpet floor of your car before vacuuming can assist you in lifting any loose dirt, leaving it cleaner than just vacuuming.
GM FRIENDS! DETAILING TIP FOR A WINDY DAY "TO PREVENT FROM SCRATCHING YOUR PAINT WHILE TRYING TO REMOVE THE DUST FROM THE WIND, ALWAYS USE A QUICK DETAIL FOR A BETTER RESULT.
Detailing tip of the week: after doing a headlight restoration you always want to use a D.O.T. approved sealant for the headlights to protect its clear coating and avoid from hazing or yellowing.
a restoration kit that has everything is actually that i've used is that new Glassylite stuff....works great.
DETAILING TIP OF THE WEEK "do you have faded black trims through out your car? using a foam applicator pad and 3 single drops of SMARTGEL you can solve that problem, by gently wiping it across the faded sections.
DETAILING TIP OF THE WEEK: how to correctly use a microfiber towel.
1- evenly spray smartdetail across your surface.
2-wait a sec for the formula to work
3 & 4- folding the towel in four,wipe side to side moving down in one direction.
5- turn tow...el around to avoid the captured dirt to scratch your surface.
6- wipe gently side to side for a silky shine finish (7)!
