Why do you ask?
I hope your not going to replace it with a lightweight crank pulley
If you are i insist on informing you why that is a bad choice.
The stock crank pulley is also a torsional dampener that prevents the engine from disentegrating itself by reducing the vibrations that an engine makes.
You see at a certain hz of vibration (if its intensity is enough) every object will shatter. Your engine will create these shattering vibrations roughly 3 times throughout the rev range and without the torsional dampener the crankshaft will in time prematurely fail.
