I let my battery go flat, leaving the lights and ipod on for 30 mins. After a jump start the disply shows Check VSC, also the traction light remains on.
Is this likely to reset itself, or is it another expensive dealer visit?
Check Engine Light's will clear themselves over time if they aren't serious. If it's still there after several startups and maybe 50? miles then you should scan the code.
I had an issue with my iPod kit that was causing startup issues. At one point one morning it cause the CEL/VSC lights to show but I wouldn't be home until late that night. On the drive home that evening the CEL cleared itself.
So if it's bad it'll linger. If it was a one-off, it'll clear itself.
Error has disappeared and not been back on for a week now (phew)
Also had an issue with the right front indicator not working. A friend (and mechanic) re-seated the bulb and it's been fine since, but I was surprised that no warning came up on the dash.
Does the IS-F not warn you of bulb failures?
1 - 4 of 4 Posts
