No, the F, and all IS's are rear wheel drive. The only FWD Lexus are the ES and the RX.
No, the F, and all IS's are rear wheel drive. The only FWD Lexus are the ES and the RX.Im not sure if it was mentioned earlier but is the F front wheel drive? Front wheel drives always have a mind of their own unless you keep your hands on the wheel. Well at least from my experience.
Wish i could man... I don't live in the states and I imported my car from the states cause they don't get the F where I live and the whole neighbouring area. I'm dying to find a way to get it solved!Have you tried 800-25-Lexus?
Also, is your pull so much that you notice it to the right, even when on the left lane of a hwy, that is graded a bit to the left, for drainage?
I realize this is my first post to the Lexus F Forums, but I might as well make it a good one. I am even going to go out on a limb and self-proclaim myself as the subject matter expert for a moment here... Please read on.Any input guys?? I just wanna understand how you guys get your cars aligned and you can't adjust the camber and the toe... These are the areas where my car needs alterations and the techs just can't find a way to do it. Other thing is I wanna get eibach springs and that will need alignment as well so how do I do it??
Thanks in advance
Thx for all the research, having trouble pulling up your documents, are they still there?I realize this is my first post to the Lexus F Forums, but I might as well make it a good one. I am even going to go out on a limb and self-proclaim myself as the subject matter expert for a moment here... Please read on.
The camber CAN be adjusted on these cars, but not in a traditional sense of being able to set the camber to exactly what you want per side independently. I just purchased my '08 on January 7th and drove it 1250 miles from St. Petersburg, FL to get home. The car has a little over 14k miles on it at this point and both front Michelin PS2s have bad wear on them (the RF much more-so than the LF). I took the car to my local dealership (North Park Lexus in San Antonio) to complain about the excessive tire wear and was initially given the usual "It will be $109 for the alignment, yadda yadda yadda..." I talked to them about the TSB regarding the pulling to the right, not to mention the 'scrubbing/hopping' sound I was getting when reversing at low speeds with the steering wheel turned at a significant angle. They agreed to align the car as a good-will gesture. Attached to this post is a text file with my "before" and "after" numbers. They ended up having to loosen the 'cradle' (I'm guessing they mean the front subframe itself) to equalize the camber numbers from side-to-side (cross-camber value). They are not independently adjustable, but you can move the entire subframe to equalize the camber values from side-to-side.
Now, the Lexus TSB # L-SB-0174-08 is an entire troubleshooting process to determine whether the 'pulling to one side' phenomenon is caused by tires or by alignment issues. The part that I could NOT find clearly explained *anywhere* on the Internet on any of the Lexus forums is what parts are replaced and how it "fixes" any supposed alignment issues.
The process for aligning these cars needs to be done like this -- if the camber is off from side-to-side, the subframe needs to be moved/adjusted until the camber numbers are equal (or, if not, EXTREMELY close). From there, set the toe properly and see where the caster falls out. *IF* the caster is off on one side or another (this can cause a pull to one side), there are different No. 2 arm brackets that can be ordered, depending on what you need to do with the alignment (i.e. if you need to move caster forward or backward on either side). There are two part numbers (one for the left and one for the right) that will move the caster +20' (plus twenty minutes, or roughly .33 degrees) and two part numbers (again, one for left side and one for right) that will move the caster -20'. The entire list of part numbers are:
Part # / Side / Offset Angle
48075-30020 / RH / 0 (stock)
48075-53020 / RH / +20'
48075-53030 / RH / -20'
48076-30020 / LH / 0 (stock)
48076-53020 / LH / +20'
48076-53030 / LH / -20'
(Source: Toyota TIS website: Document ID #: RM000000WWZ016X)
I have scanned a printed copy of this document and placed it on my home server here: http://rickyc.mine.nu/website/ISF/ISF-Alignment.pdf
Now, I am not going to get into a step-by-step on how to fix the issue (I already pretty much have above), as it would take me quite a while to explain what impacts camber, caster, and toe have on vehicle dynamics and tire wear, but suffice it to say I now have my car set up to maximize handling while minimizing tire wear as much as possible (again, please reference the attached .txt file to see where my alignment settings are at this point -- keep a close eye on the toe settings and the now-nearly-equalized caster settings). The car feels entirely different at this point, and I was actually lucky enough with my vehicle that the dealership didn't have to replace any of the No. 2 arm brackets once they got things where they needed to be.
In addition, I have a copy of the Lexus Service Bulletin on my same site that I linked above. You can view and/or download either of them by going to the parent directory: http://rickyc.mine.nu/website/ISF and right-clicking -> Save-as the files.
Best of luck to you all that have the pulling to the right problem.
