mmmmmm tasty
No that was a twin turbo setup. We are expecting the same if not better results with our single turbo setup. The single turbo should make the same power but spool much faster!Is that from the single turbo setup?
You are correct. Our kit will be mounted in the engine bay, which should result in faster spool and a better performing kit over all. Our plan is to try not to use methonal, but if we have too then it also will be mounted at the front of the car. The air fuel ratio in this graph overall is very good! The amazing part is that we actually had good control of the ecu. I am still in the process of figureing out a way that we can use the direct injection signals to give us even MORE control of the fuel! For the power we are at now I can say that this is most likely the best tune on a forced induction IS F yet.Congrats on the numbers!
This setup is the Artisan right?
Did you say your single kit will mount in the engine bay?
No we have added larger port injectors.did you use the stock injectors?
It's getting cold up here, we'll see if there are any track days that we/the customer can get to.Congrats Andy, now you can take it to the strip.
There is a good chance we'll work with AEM, but Aquamist isn't out of the question.and if you do go meth please get with aquamist (industry leader) and get the best setup possible rich can do amazing things.
oh and nice numbers.
http://www.lexusf.com/forums/showthread.php?t=1950Wow. Wow. WOW!!! Just curious, any prospective number for an installed unit yet or Kit?
car DVD player online store
Lexus IS200 IS250 IS300 Car DVD Player Navigation system Car DVD Player+ 7 Inch Digital touchscreen+Dual Zone+Built in GPS DVB-T
High Quality: Made by a very famous manufacturer in China, extended warranty: 2 years!
7 Inch TFT high-definition Digital LCD Screen, 800*480 resolutions!(2,650,000 color), support 4:3, 16:9 and full screen display!
Specially Designed for Ford Mondeo. No gap with original dashboard after installation.
Convulsed timbre and enjoy all your journey
iPOD Ready, Steering wheel control, CDC port, TF Card slot for GPS and music files(support up to 16GB TF Card!).
Completely Dual Zone Playback, you can run the gps application while listening to Radio/CD/DVD/music in TF Card/USB device
Built-in Digital TV(Only with European Standard is available) is also optional, and it need 220usd to add this function. Please contact us if you are interested in DVB-T function. *Bluetooth function have be included
