18" wheels for trackday - Lexus ISF / IS-F / LFA / LF-A Forum
Thread Tools Display Modes
post #1 of 5 Old 02-26-2012, 09:36 PM Thread Starter
abyars
Senior Member
abyars's Avatar
Quoted: 0 Post(s)
I need some help guys. Does anyone know if the 18in wheels from the IS350 will fit on the ISF and clear the caliper? I am going to set up a seperate tire/wheel combo for track days. I just about ruined a set of PS2 All Seasons this weekend
_____________________________________________
2008 Mercury Metallic IS-F, Takeda Intake System (154.1 Texas Mile Oct 2011)(13.13 @110 IFO Ennis TX)
2008 BMW 650I Convertible (wife's)
abyars is offline
Sponsored Links
Advertisement
post #2 of 5 Old 03-01-2012, 02:39 PM
Carbon
Senior Member
Quoted: 0 Post(s)
The dealership mentioned they used the aftermarket (F Sport?) rims from the IS-250/350 for mounting winter tires on the F.
Other than that, I used tire rack to find compatible 18" rims for my winters. I ended up with Enkei Imola wheels. AFAIK tire rack is the best place to check fitments because they check calliper/strut/fender clearance on all their wheels for you... provided they carry the brand you want.
Carbon is offline
post #3 of 5 Old 03-01-2012, 03:00 PM Thread Starter
abyars
Senior Member
abyars's Avatar
Quoted: 0 Post(s)
Thanks I will check on it.
abyars is offline
post #4 of 5 Old 03-01-2012, 11:50 PM
Digger08
Member
Quoted: 0 Post(s)
I have run for winter G Spider's and X Package rims from the IS250/350 in 18's no problem
Top my knowledge the F-sport will not fit in 18 and 19 in factory off sets. I believe the front spokes will hit the calipers. I will also assume that being race tires you do not want spacers.
The X-package are staggered and the G Spider's I had were not - but they all fit in 18's. You can get G Spiders staggered as well.
Specs
X Package
Size: 18 x 8 inches Fronts & 18 x 8.5 Rears
Bolt Pattern: 5-114.3
Offset: 45 mm Fronts / 50mm Rears
Weight 27.30 lbs Fronts / 27.75 lbs Rears
G Spiders
Size: 18 x 8 inches F/ 18x8.5 R
Offset: 45 mm F/ 50mm R
Weight 27.65 lbs F/ 28.35 lbs R
Accepts TPMS Sensors
Using the off-sets above are very safe and you will have no clearance issues at all.
Digger08
Digger08 is offline
post #5 of 5 Old 03-02-2012, 02:50 AM Thread Starter
abyars
Senior Member
abyars's Avatar
Quoted: 0 Post(s)
WOW thank you very much for the info.
Andy
abyars is offline
Sponsored Links
Advertisement
Reply
  Lexus ISF / IS-F / LFA / LF-A Forum > Lexus IS-F Discussion > Performance Modifications
Quick Reply
Message:
Options
Register Now
In order to be able to post messages on the Lexus ISF / IS-F / LFA / LF-A Forum forums, you must first register.
Please enter your desired user name, your email address and other required details in the form below.
User Name:
Password
Please enter a password for your user account. Note that passwords are case-sensitive.
Password:
Confirm Password:
Email Address
Please enter a valid email address for yourself.
Email Address:
OR
Log-in
User Tag List
Thread Tools
Show Printable Version Show Printable Version
Email this Page Email this Page
Display Modes
Linear Mode Linear Mode
Forum Jump
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
For the best viewing experience please update your browser to Google Chrome
